info for microsquirt on digifant 2
gofgtig60
Post by gofgtig60 »
hi..i'm from italy and i have a golf gti mk2 1.8 8v.. i've another engine 1.8 8v g60 160cv and i'dd like to install a microsquirt to it..what i need for this? i haven't a TPS and a cam or crank sensor.. there is only a 4 windows distributor
Re: info for microsquirt on digifant 2
The 4 tooth distributor trigger will work fine unless you want to use a distributorless ignition.
gofgtig60
Post by gofgtig60 »
Matt Cramer wrote:The 4 tooth distributor trigger will work fine unless you want to use a distributorless ignition.
i would like a wasted spark ignition
In that case, your best bet is to throw a crank trigger on there - I think there may be some later VW engine with a 60-2 that bolts on. You could potentially also use the 4 tooth distributor trigger if you added a one tooth second trigger.
