60-2 trigger punto gt
papagias
Post by papagias »
hi i have a problem with oem hardware on punto gt it revs until 6800 and then lost sync i have tried diferent resistances
Re: 60-2 trigger punto gt
Exactly what resistors have you tried and where were they connected?
Is this a V3.0 (plastic case) or an earlier MicroSquirt?
papagias
Post by papagias »
it s v3 and i have connect resistors in line to vr sensor 10-15-20-25-30kohm
Try using a 10K resistor across the two wires instead of inline.
papagias
Post by papagias »
i tried this the same thing. i ve tried also firmware update to 3.83 from 3.3.1 but ihave to read the manual for the trigger configuration :(
If running the Extra code, see if you can get a tooth log of the breakup and post it here.
papagias
Post by papagias »
after the update i cant go to diagnostics and high speed loggers but i have one from the old firmware 3.3.1
2014-12-10_18.54.09.rar
(40.91 KiB) Downloaded 442 times
Try a 4.7K or lower resistance value instead, in parallel with the sensor.
papagias
Post by papagias »
i tried no luck i m going to try ahall efect sensor this solotion is good for some other ecus
