That won't work with the standard B&G code OR the Extra code, although there is an unofficial patch that allows the Extra code to use that wheel with a special filter circuit. That said, the stock wheel isn't the best for EFI; if you have the ability to swap in a 36-1 wheel, that's probably your best bet.
Note that the B&G code only allows 2 ignition channels; if you want true COP, you need to switch to the Extra firmware.
Edit - Actually, depending on the OD of your wheel and the maximum effective width of the tooth tip, you might want to go with a 24-2 or 12-3 wheel; the extra-large gap also helps with the speed changes during cranking with a high-compression engine.
