Wont Idle
mrshardface
Wont Idle
Post by mrshardface »
2014-01-13_17.43.34.msl
data log
(33.56 KiB) Downloaded 305 times
2014-01-13_17.43.15.msq
tune
(30.21 KiB) Downloaded 313 times
Good Afternoon guys
I have spent the past month setting up my microsquirt module to run my turbo 22ret fuel only
i want to run 10psi
Sensors
GM 2 bar map sensor
GM Air Temp sensor
GM coolant Temp sensor
Ford tps - EB Falcon
innovate mtx-l wideband
Bosch 440cc Injectors 0280-144-968
50psi Fuel Pressure (tested) with el xr6 Fuel Pump
Microsquirt V3
It starts for a second then turns off i cant keep it running no matter what values i change i get a rpm spike from noise but it steadies out
i have masked it in many of my other trials but cant keep it running
Can some one more experienced than me please have a look at my attached tune and quick data log of ..cranking starting then dieing ..and repeat
Will pay if some one can do me a base tune to start this thing
tune
mrshardface
Re: Wont Idle
Triggering off Coil Negitive
Re: Wont Idle
Try increasing the Skip Pulses setting. This will make it reject the initial noise burst, but may result in a slower start.
Also, how exactly are Opto In + and Opto In - wired up?
