Trouble starting
James H
Trouble starting
Post by James H »
I've got a sequencer, and am not getting any sort of starting success, not even a cough. I tried some starting fluid, and after some cranking got a cough and a backfire out of the throttle body. An inductive timing light flashes as I crank, it's really hard to see the timing numbers while cranking, but I think I'm around 20 degrees. I'm using a 36-1 wheel with and a distributor-mounted cam sync tooth. I've double-checked the teeth between the crank sensor and tooth 1, and the cam tooth. I'm not sure where I should start with the injector pulsewidth for cranking with this setup. The engine is 416CI V-8, and I the injectors are 39lb/hr (8 injectors). The default was something like 11ms at -40F and 3ms at 160F. I adjusted these from 1.5ms up to 13ms, but nothing happened. I'm wondering where a good place to start is for this. I'll also keep trying to get a better look at the timing, but if it is about 20 degrees, it should start fine as that is close to where I ran before the MS conversion. I attached an msq and log also.
1.5 cold pw.msl
(70.43 KiB) Downloaded 424 times
2013-10-04_20.03.34.msq
(30.23 KiB) Downloaded 393 times
James H
Re: Trouble starting
Post by James H »
OK, I found that it works much better when I put a fuse in the fuel injector fuse holder. Before that, though, I spent more time with the timing light and found my crank offset was about 20 degrees too advanced. It was probably good to figure that out before injecting fuel. After putting a fuse in place, I got it to fire up, but it is rough. It looks like my O2 sensor isn't working, and there are probably some other issues, but now that I know it fires up I should be able to work through them.
