Microquirt with Coil on Plug
agent4573
Post by agent4573 »
I'm new to this and apologize if this is answered in the manual, as I'm at work and the site to get the manual is blocked. I'm building a dune buggy with a Nissan "VG" V6 in it. It uses "direct fire" or coil on plug type ignition and I was wondering what it would take to make the microsquirt work with it. The stock system has a "Power Transistor Unit" which acts as 6 seperate relays to turn low power inputs into high current circuits for the coils to charge off of. It takes 6 inputs, one for each coil. From all the reading I've seen, the MS can only do 2 banks of firing, so even if I combined cylinders I would be one bank short to turn it into a wasted spark type ignition. Can I add the sequencer and get away with 6 cylinders all direct firing, and if I do, can I do away with the PTU or should I still use it in conjunction with the sequencer?
Re: Microquirt with Coil on Plug
agent4573 wrote:I'm new to this and apologize if this is answered in the manual, as I'm at work and the site to get the manual is blocked. I'm building a dune buggy with a Nissan "VG" V6 in it. It uses "direct fire" or coil on plug type ignition and I was wondering what it would take to make the microsquirt work with it. The stock system has a "Power Transistor Unit" which acts as 6 seperate relays to turn low power inputs into high current circuits for the coils to charge off of. It takes 6 inputs, one for each coil. From all the reading I've seen, the MS can only do 2 banks of firing, so even if I combined cylinders I would be one bank short to turn it into a wasted spark type ignition. Can I add the sequencer and get away with 6 cylinders all direct firing, and if I do, can I do away with the PTU or should I still use it in conjunction with the sequencer?
It is possible to use the MS2/Extra code to get three spark outputs (you'd use WLED with a pull up for the third) but not six.
The Sequencer hasn't been released, but it was its own ECU and not an add on to the MicroSquirt. Its nearest available cousin is the MS3-Pro, which uses the same case and some circuits developed for the Sequencer, but uses a single large processor instead of two smaller ones.
agent4573
Post by agent4573 »
After I posted I continued reading and realized that the sequencer was a stand-alone unit. It really seemed like it was an add-on board/kit that you could just plug into the Micro and use as a combo unit. No worries though, I'll just have to save up and get the MS3 when I'm ready to add the turbos on. Thanks for the reply.
EDIT* My other option I was considering was geting a ford EDI unit to use with the Micro, but I would like to reuse as many parts as possible and going that route would mean a completely different ignition system entirely.
