CLT sensor erroneous reading in 3.83
Here is my setup:
MS V3 on a 1981 Suzuki GS1000, which is an air cooled 4 cylinder 4 stroke motorcycle. I am running version 3.83.
The bike has 2001 GSX600 throttle bodies & injectors.
CLT sensor is a thermistor mounted in a ring terminal and bolted to a chunk of aluminum that is between the fins on the back side of the head. It and the IAT sensor were calibrated in Tuner Studio using the 3 point entry and 2490 offset values. I have table data for each thermistor and entered the value for three points: 0 degrees C, a mid-range value, and the top value. For CLT, this was 0, 150, and 300 degrees C.
IAT sensor is a thermistor mounted in the airbox.
O2 is a Bosch WB controlled by a BPSX controller, which outputs AFR 9 at 0V and AFR 19 at 5V.
MAP sensor is a GM 1-bar.
TPS is the GSX sensor calibrated via Tuner Studio.
The bike won't start, but in this post, I want to try to figure out why mt CLT reading is constantly like -32 degrees F. It worked properly in v. 3.77 and also when I tried the MS Extra firmware, but in version 3.83 it is flaky. I have done the three point calibration repeatedly with no effect.
I'll attach a MSQ file for reference.
- Attachments
- 2013-05-06_01.59.31.msq
- (30.21 KiB) Downloaded 196 times
Adapting fuel injection mostly from a 2003 GSXR600 via a Microsquirt
Hearing "It can't be done" is SOP around here.
Re: CLT sensor erroneous reading in 3.83
UPDATE
This made no difference, so I reloaded v. 3.78 and the CLT sensor works properly again.
