C20let on Microsquirt - Miss firing issue?
C20let engine
86.5mm pistons,
T34 Turbo and manifold with external wastegate.
LC-1 Wideband
3" downpipe and exhaust system
3" Boost Piping
Adustable Fuel Regualtor Set at 3 Bar.
Limited to 300cc injectors.
Wasted spark from an XEV Engine
Microsquirt V2 - MS2 Extra Code.
Ive had a few problems recently one having the old head lift and the gasket go.
I have rebuilt it with a coscast head and cosmetic tripple layer steel head gasket and new stem seals etc.
Turbo has had a rebuild too. I know that 300cc injectors will only be good for so much hp but i just want to get her running for an mot i will upgrade the injectors in the next few months (building a new inlet from injected bike carbs )
So its all back together and is running however the problem now is the car seems hesitant until i adjust the Warmup enrichments and hit 'burn' whilst its running, it then picks up and gets rid of this miss fire and runs lovely, but each time i power the engine off and restart the miss fire re emmerges. Ive checked most my reading and they seem ok, ive noticed the coolant spikes a bit but nothing drastic.
I have had new ht leads fitted at the weekend and tested on 3 differnt coil packs but the problem is still there.
please could some one help me ive been scrathing my head for a few months now on this issue. i have cleaned all grounds ( im using a hks circle earth )
I will attach a Data log and my car's setup files if someone could help id be much appreciated.
Cheers
Al
Re: C20let on Microsquirt - Miss firing issue?
If someone could take a look id be much appreciated .
noticed i'm running 3.2.1 MS2 Extra im going to try updating tonight to 3.2.4 and hopefully that will fix my issue
https://www.wetransfer.com/downloads/4d ... 843/122d2a
2013-04-08_19.43.45
Cheers mate
I just uploaded the new firmware for ms2 extra (mine was on 3.2.1) and now its on 3.2.4, it is working very well, no more miss firing
Time for a tune me thinks
