I'm wondering if I can setup the idle control on my V2 microsquirt to control a fan instead? Looking at the settings in TunerStudio it looks to be coolant temp based all ready. I'm not sure if it energizes the output when the coolant temp is reached or cuts the output on that pin though. It seems like something people would have tackled before but I haven't found anything in searching yet.
Take a look at the MegaManual page on Spare Output Ports. Basically, a 'spare' port isn't one you're using for something else. If you aren't using your FIdle pin for, well - Fast Idle, you can certainly use it for something else. Be sure and turn the 'Idle' function off by selection 'None' for the Idle Control Algorithm.
In TunerStudio - Idle control is the second selection in the "Fuel Setup" tab. Spare Ports is the third selection under that tab.
Got it working. Only gotcha was the wiring, it wasn't clear at all how to do it. Since the pin was labeled as an output I tried to drive a relay with it and it didn't work. After way to much searching I found a wiring diagram. Turns it out it grounds the pin. A couple wiring changes later and it's all good.
