problems.
classic-indy
problems.
Annoying part is that I had the engine running and starting smooth just a couple days ago. I did increase priming pulses and cranking pulses. However, the engine is definitely NOT getting fuel.
Re: problems.
You may have the PWM parameters set incorrectly. See: http://www.megamanual.com/mt28.htm#sn But your fuel pump may be plugged, or there could be other issues.
In any case, you'll get more informed help if you tell us what code version you are running, and post an MSQ file (i.e. your settings) AND a datalog.
classic-indy
Re: problems.
classic-indy
Re: problems.
classic-indy
Re: problems.
Sounds like it's flooded; the misfires pump unburned oxygen into the exhaust making the sensor read lean. However, it may instead be that there's a leak in the exhaust causing the sensor to read lean, and the EGO feedback loop is richening the mix to try to compensate. If this was mine, I would make sure EGO feedback was disabled until you sort it out.high duty cycles underload and very lean readings on the AFR
classic-indy
Re: problems.
I have tried dis-abling the EGO correction, with little luck. Do you think I should go through my AFR tables and slowly lean them out???
Another thought I had was that my injectors don't have enough time to inject the required fuel. Max 8500 rpm with 2 squirts per rev. = 283 injection events per second. Thinking about trying alternating pulses for the injectors. See attached video of a data logging session.
http://www.youtube.com/watch?v=wqO_wIcq ... e=youtu.be
Re: problems.
Lorne
classic-indy
Re: problems.
I continued increasing the fuel, and this is where I am at (see youtube video). Almost seems that I can't get enough fuel with these injectors to sustain WOT. Duty cycles are much too high and I can't sustain a cruise at high throttle motor dies out. Seems like I can't deliver enough fuel in the given time, for 8500rpm with these injectors. So my equation governing injector size has become time to inject fuel at WOT and not horsepower.....Thoughts?
p.s. currently re-reading injector selection.
Rich mapping:
http://www.youtube.com/watch?v=QRFt63cb ... e=youtu.be
- Attachments
- VE+'DEC29th.msq
- (26.02 KiB) Downloaded 66 times
classic-indy
Re: problems.
REQ_FUEL= 1.7 (calculated using tunerstudio)
VE= 70% (from VE table)
lowest MAP reading I aquired from the MSQ's and it's 77.6 KPA.
PW = (1.7 * 0.7 * 0.776) +1msec = 1.92msec
The same calculation with 75 lb/hr injectors is 2.03msec
