Can someone clear up VR sensor wiring on the V3 MicroSquirt?
Posted: Wed Aug 15, 2012 6:16 pm
The wiring diagram here says the following:
Pin 33:
Pin 33:
Pin 21:Variable reluctor A/C signal input (ground) for Input 1 & Input 2 (if used). Note that you can use only one of OPTIN+/- or VRIN+/-, because they connect to the same processor pin. For the second ignition input (Input 2), use VR2IN+ (Ampseal pin 4). For more info, see: vr.htm
So, if I have a VR input 2, i.e. a 2nd VR sensor, which wire does its ground connect to- pin 33 or pin 21? ... or both? ... or either?This is the ground pin for the second variable reluctor input (typically for a VR or Hall camshaft sensor). For use with a variable reluctor sensor (that has an AC signal) connect this wire to the second VR sensor wire. For use with a Hall sensor, leave this wire 'floating' by snipping it off and sealing it. For more info, see: vr.htm
