Installing lambda/O2 on twin exhaust
Posted: Tue Jul 03, 2012 10:54 pm
by spandit
I'm planning an install on a 4-cylinder engine. Despite the cylinders being in-line, there are two manifolds that lead to the exhaust. Can I just install the O2 bung into one pipe or would I need to join them somehow? Can MS (MicroSquirt) cope with multiple O2 sensors?
Re: Installing lambda/O2 on twin exhaust
Posted: Wed Jul 04, 2012 11:45 am
span,
You can do either. Many V8s came with a single sensor in one bank back in the 1980's and it worked fine. But you can also use dual sensors, see: http://www.useasydocs.com/details/ego.htm and http://www.megamanual.com/mt37.htm#se
Posted: Fri Jul 20, 2012 12:50 pm
by spandit
Thanks, Lance. Going to need welding either way so will design something suitable
Posted: Sat Jul 28, 2012 3:53 pm
by abecedarian
If the manifolds eventually come together to one pipe, install a heated O2 there.
