How to drive Honda RC-51 RVT Ignitor Box?
This ignitor box has 6 wires. Plus, minus, two inputs, two outputs.
It works with a 5V signal somehow....
The coils wired to the outputs share a common GROUND. (no not +12V)
I'd set it up: Falling edge, going high inverted, COP. Max dwell 3ms.
It works, but at 6k ish there's this invisible rev limiter and i don't get resets, sync losses or anything.
So i raise max dwell to 4ms. This brings down the invisible rev limiter to way lower RPMs. So i drop max dwell to 2.5 later even 1.5
Fires up 'n runs much better, i get up to 8300 RPM now.
As dwell strikes me as too low, i guess it's telling me it needs to be triggered differently. How?
This is the box:
- Attachments
- Honda RVT RC51 ignitor box.JPG (12.43 KiB) Viewed 1468 times
Re: How to drive Honda RC-51 RVT Ignitor Box?
Anyways if YOU are the next one to use one of these. Go easy on the dwell !!!
And i guess the manuals can use a CDI section.
And bikes are not (half) cars.
