Turbo motorcycle
Posted: Sun Apr 22, 2012 7:08 pm
quick run down of the bike
82 yamaha XJ650 stock engine 9:1:1 comp
home built turbo kit on 9psi
microsquirt
quadspark
420a neon coil
3 bar map sensor
gm iat and coolant temp
36-1 trigger wheel with one stock vr sensor
03 gsxr 750 throttle bodies with 240cc injectors
The story
Ive had this running for about 2 months and ive been making small changes to make it run better and better so ive been running 37 degrees under heaver loads like 2500-3500k up and 36 degrees under boost and its been running ok in part throttle and has been running really good under boost. the problem ive been trying to fix is the bike had no power unless in boost like 1st gear it just wouldnt go so tonight i was messing with the tune and i put the higher load timing at 49 degrees and i went to rev it in the garage after uploading and wow it revs like a rocket so i went for a ride around the block and wow man it has power in all gears now with out boost and i left boost timing at 36degrees. I went for a hard ride and came back and pulled the plugs and checked timing marks on plug straps they were right in the middle of the strap which is good.
The questions
Do these smaller engines take more timing???
How to tell what timing a engine needs???
Do you think 36degrees is too much in boost??
microsquirt
quadspark
420a neon coil
3 bar map sensor
The story
The questions
