Fuel pump relay Cycling - V3 Microsquirt
Posted: Sun Apr 08, 2012 12:33 pm
Hi Guys, this is to replace previous post in which I mistakenly called my processor an MS3 and therefore got hoofed off to another message board.
I have run through all the installation info I can find; added a 47uF capacitor between Vref and sensor ground; checked all wiring; checked grounding; reloaded code; have no comms problems but TunerStudio can't keep connected with the controller cycling off and on every one second. It does this any time it is powered up except when the bootloader wire is grounded, whether connected to the laptop or not, whether sensors etc. are connected or not. Are there any other things I can try, or could I have a bung Microsquirt?
Cheers
Nick
Cheers
Nick
