Map Sensor Wiring
Posted: Sat Mar 10, 2012 1:59 pm
by rsaint
Have a MPX4250ap-ws and cannot find a wiring diagram for the pinout not mounting it on a board just externally is there any place this can be found.
Re: Map Sensor Wiring
Posted: Sun Mar 11, 2012 5:00 pm
by dontz125
Pin 1 (with the notch) is the 0-5v signal. Pin 2 is GND, pin 3 is +5v. Pins 4-6 are not used. Solder and heat shrink the appropriate wires to the first 3 pins; I would strongly suggest that a 3-4" flying wire be soldered and heat-shrink'd to the other three pins, and then taped or shrunk to the main wires. This will provide greater strength to the overall assembly.
Posted: Mon Mar 12, 2012 4:41 pm
by rsaint
dontz125 wrote:Pin 1 (with the notch) is the 0-5v signal. Pin 2 is GND, pin 3 is +5v. Pins 4-6 are not used. Solder and heat shrink the appropriate wires to the first 3 pins; I would strongly suggest that a 3-4" flying wire be soldered and heat-shrink'd to the other three pins, and then taped or shrunk to the main wires. This will provide greater strength to the overall assembly.
Thnks helps alot.
