TACHOUT is inop
Posted: Sat Mar 10, 2012 1:35 am
Hey,
I have completed the intallation of microsquirt V2 on my ER5 bike and have the engine idling and revving ok. However, I am unable to get a tach out signal.
I have wiried it up to the OEM tacho which is a 12V gauge and I have set TACHOUT to ON at normal speed, using the TACHOUT signal wire and it does not work, I have also tried swapping the Tach signal to use WLED, ALED, and F-IDLE as I am not using any of these wires for anything and it still does not work. I am coming short of installing a tach adapter. But i would really like to rectify the problem and install that as a last resort.
It is hard to auto tune the engine without knowing what the exact rpm. I only know roughly what the engine speed is by listening while I ride
Do you have any ideas on what may be causing this problem?
Cheers,
Matt
Cheers,
Matt
