display problems + blue screen of death.
Posted: Wed Nov 16, 2011 3:27 pm
by classic-indy
When I run the machine I randomly get the blue screen of death. I'm running Windows 7, 1.66ghz processor and 1 Mb RAM. Any thoughts?
Also in Ve analyze live I can only see 2 filters without the option of scrolling. And I can only see half of those two filter tabs. for min and max rpm. I've briefly tried to alter the computer visuals without luck.
Re: display problems + blue screen of death.
Posted: Wed Nov 16, 2011 3:35 pm
by LT401Vette
There is only 1 known cause of the BSOD for TunerStudio.
USB to serial cables based on the Prolific chipset. Prolific had a nasty bug in their driver for quite a long time, that i believe they have finally fixed. There is more in the faq on my site about how to fix it.
I still always recommend FTDI based cables.
http://www.efianalytics.com/TunerStudio/faq.html
What resolution are you running?
You should be able to see everything on as little as 600 pixels high, but you need to mind what look & feel you are using and will likely need to hide the live graph at the bottom.
The newer betas have quick hide options for the graph.
Posted: Wed Nov 16, 2011 8:10 pm
by classic-indy
resolution is 1024x600. I believe I'm using a prolific usb to serial cable, but I'm not at home because of work for the next few days. I will start reading for usb to serial solutions.
