Wiring in relays for fan/water injection control etc.
anonymous.shyster
Recently purchased a microsquirt V3 and was not able to procure a relay board, as I was told B&G aren't manufacturing them at present. What options does this leave me for things such as fan control, water injection etc. Of course, these require relay operation. Is it as simple as buying a standard automotive relay, and wiring it up?
Thanks.
- Master Squirter
Re: Wiring in relays for fan/water injection control etc.
I think this is covered in documentation, but for fan control a relay works for me.anonymous.shyster wrote:...Is it as simple as buying a standard automotive relay, and wiring it up?
anonymous.shyster
Product info - http://www.ttrignition.com/rugged-efi.html
anonymous.shyster
I'd like to have fan control (+1)
Water injection control (+1)
Intercooler water pump (+1) so it isn't always running
That's four. I can probably get away without wiring the fuel pump up to the MS, since I'm using carburettors. So four may do, if I haven't forgot anything. :/
Hmmm ... I might wire a jumper to the 'main' output; that way the spares would be ... Nope. That would bypass the 'fuel' relay, and everything downstream of it would be powered when the 'main' relay comes on. Hmph.
anonymous.shyster
anonymous.shyster
Intercooler fan and pump is turned on and off depending on the intercooler (water to air) coolant temperature. If the coolant (non-glycol) gets to a temperature 7C above ambient the fan and pump are running OR if the throttle exceeds a threshold (1/2) it will also come on. The fan and pump are turned off again after another threshold has been reached, i.e temperature is now 5C above ambient. I'd like to able to do this, it does sound efficient, doesn't it?
