Regulators
Posted: Fri Apr 15, 2011 10:36 am
by classic-indy
I'm Currently working on Microsquirting my snowmobile, and I've got a wiring question. The snowmobile has a 14.3 AC volt regulator currently installed on the snowmobile. Can I wire this in or will I damage the ECU???
Next question, do I have to run the ECU on DC power? or will AC suffice.....
Re: Regulators
Posted: Fri Apr 15, 2011 11:53 am
Definitely DC.
Re: Regulators
Posted: Sat Apr 16, 2011 7:02 am
by classic-indy
Re: Regulators
Posted: Sun Apr 17, 2011 7:22 am
by dontz125
Unless I'm sadly mistaken, EVERYTHING relating to EFI is DC - pump, injectors, sensors, and most definitely the uS controller.
Is your alternator 1- or 3-phase? Either way, I'd recommend you check around on EBay and look for a recent-model voltage regulator / rectifier - the Yamaha R6 has a proven design, and can be had for $40-60 from various wreckers.
I assume this is the lighting coil - the few-hundred Vac of the CDI charging coil would be difficult to deal with. How many watts does your alternator put out?
Re: Regulators
Posted: Fri May 06, 2011 8:01 am
by classic-indy
280 W, I ordered an AC/DC converter, and when I got it and immediately read the instructions and it can only handle max 6W........DOH!!!!
Re: Regulators
Posted: Fri May 06, 2011 9:15 am
dontz125 wrote:Either way, I'd recommend you check around on EBay and look for a recent-model voltage regulator / rectifier - the Yamaha R6 has a proven design, and can be had for $40-60 from various wreckers.
classic-indy wrote:280 W, I ordered an AC/DC converter.....
Good advice... not taken! That's the big :oops: :)
PS I would have got a bike regulator too. 8)
EDITED 'cos I didn't get the quote tags right & it took 4 attempts! :oops:
Re: Regulators
Posted: Fri May 06, 2011 9:49 am
by dontz125
Hate it when that happens... :?
Seriously, get a modern VRR from an R1 or R6 or something similar from a bike wreckers. Medium AC-DC regulation and conversion is what they do, and do it very well.
