500CC 180 degree parallel twin motorcycle conversion
triangles95
Ignition:
Use a 36-1 trigger wheel on the flywheel and 1 tooth trigger on the intake cam.
Am I correct in thinking the µs can use the 36-1 to know when cylinder 1 is at TDC and the cam sensor to discern Combustion from Exhaust stroke. Then with this information the µs can calculate the 180 degree crank rotation to fire cylinder 2? Initially I plan on using only these two sensor as the stock ignition is only RPM advance.
If anyone has sources for sensors that could be used for cam/crank it would be helpful. I was thinking of using Hall sensors since I think in theory they work better than VR. Does one sensor type or the other work better with the µs?
I would leave the stock ignition intact and use a timing light to get the µs synchronized with the factory CDI box. Then I could remove the factory ignition and use µs in it's place. I may need a refresher on ignition coils but in a conversion of a suzuki DR450 over on the thumper talk forum. he said the µs could not use the factory coil? I hope this is something particular to that bike. Is there any reason why I wouldn't be able to have the µs fire my stock coils?
Sequential Fuel Injection:
With the ignition functioning equivalent to stock I would move on to the FI goodness I would make a custom intake similar to what was done on a Ninja 250 is in this thread. I plan on using a 38mm throttle body from a Suzuki Burgman AN400. It has the TPS, MAP sensors built in. I could simply add an IAT to the intake plenum and a coolant temperature sensor. I have two injectors from a Ninja 650 that I plan to use and I'll figure out what vehicle I'll use a fuel pump/regulator from when I get to it. I'm debating on whether or not it's worth while to use an WB O2 for a feed back loop. At the least A WB O2 would be very helpful for tuning.
I think that just about sums it up. Am I missing anything? Does anything stick out as a no way in Hell will that work?
- Master Squirter
Re: 500CC 180 degree parallel twin motorcycle conversion
You might find if you look in msruns there is a similar project to yours and there are a few motorcycles now.
