Microsquirt repair needed who to send to?
kvw
Post by kvw »
I had the option+ hooked up for my tach signal and was told to ground the option- because there was no clarity at that time what to do with it. Well i had a problem where it lost tach signal after 8hrs of no stop running. Fuel pump would cycle with a flip of the switch but not during cranking. Then i researched and seen your to hook it up to a 12v source. So i think i fried something and need it repaired if possibly. Thanks Ken
Re: Microsquirt repair needed who to send to?
Most likely, the R20 resistor is burned.
If you bought it from us, please email me at websales@diyautotune.com directly.
Peter Florance
Post by Peter Florance »
Matt Cramer wrote:Most likely, the R20 resistor is burned.
If you didn't and need service, contact me: peter@pftuning.com
