Dual spark
old-colt
Dual spark
Post by old-colt »
I am working on a project and am wondering if anyone is running the Dual Spark code with factory pickups?
I seem to see references to changing bikes to multitooth trigger wheels but have not seen any mention of running Microsquirt for what it appears to be designed for. Two pickups with two coils.
Cheers,
Charlie,
If it ain't broke, Modify it!
http://ffmsd.com/
http://www.cardomain.com/ID/old-colt
adam.bonhamcarter
Re: Dual spark
Post by adam.bonhamcarter »
+1 on this question
I have a GPZ900 '84 with two VR pickups 180 degrees apart that I would like to use to reduce the mods required from stock
Re: Dual spark
adam.bonhamcarter wrote:... with two VR pickups 180 degrees apart that I would like to use to reduce the mods required from stock
The only mod you'd need is to lose one of the pick up teeth. Not ideal as a few more teeth is better, but would work anyway. :?
crank triggering- independant dual ignition
Re: Dual spark
If it has only one tooth on the wheel, it may work with no mods at all.
adam.bonhamcarter
Re: Dual spark
Thanks Matt
I'll give it a try and post results ... not going to be for at least a couple of weeks tho'
ABC
ZGRX1000
Re: Dual spark
Post by ZGRX1000 »
I have the same setup, what was the outcome. I did try to use a single input but was unsuccessful. Look forward to your replay, Paul
