No/curious triggering of injectors
Super_7
Post by Super_7 »
Hi!
As per manual I should not spend more than 15 minutes to get my engine running, but after I spent weeks I decided to post my problem before I get mad!
My configuration:
Standard Ford Zetec 1.8L 115PS, Ford-EDIS-module, small air intake manifold, original Ford Mondeo fuel injection system, Microsquirt code 2.890 and Megatune 2.25.
Everything wired, Sensors calibrated, ignition spark is running, prime-pulse during switching ignition is available! (To show it I use a LED)
Setting: 4 Cylinder, 4 Injectors, 2 Squirts, Simultaneous)
Problem:
During cranking (MT shows "Cranking") the injectors (high impedanc) are only triggered (by a VERY short impulse compared to the usual when I use the original Ford ECU) when I open the throttle nearly to maximum. (TPS is calibrated correctly!)
So overall the engine does not get any fuel and does not even try to start.
Logfile says:
- RPM between 0 and 138
- As long as the RPM is between 0 and 3 PW is 4.3
- Above RPM 3 PW is 0
- Opening Throttle > 70 PW is 0.3
What's already double and triple-checked:
- Input voltage(s) are available before and during the cranking process
- Wiring of injectors is ok. Injector test-mode is running without any problems. Prime-pulse is available
- Fuel is calculated automatically by around 17 Liters. Rather too much than too less...
- oxygen sensor disabled
I'm open for any ideas how to proceed...
I saw that somebody posted the same problem years ago and solved it by switching to an older (!) code. Would this make sense?
Thanks,
Roland
datalog201003282220.log
(347.17 KiB) Downloaded 129 times
2010_3_27.msq
(25.05 KiB) Downloaded 129 times
Peter Florance
Re: No/curious triggering of injectors
Post by Peter Florance »
I think you should post your msq and a datalog of your starting attempt. I suspect you do not have the trigger wheel set up correctly.
This looks like a firmware corruption issue. Try reloading the code and copying your settings over by hand instead of reloading the old MSQ.
Peter Florance
Matt Cramer wrote:This looks like a firmware corruption issue. Try reloading the code and copying your settings over by hand instead of reloading the old MSQ.
I think so. Is coolant in C?
I noticed it's only 9 degrees and IAT is -31 degrees
800vtwin
Post by 800vtwin »
2 things to emember:
-The cranking pulsewidths are set independantly of the VE table.
-tps above 70-75% (settable) activates clear flood mode (fuel cut) during cranking.
Peter Florance
800vtwin wrote:2 things to emember:
all that stuff is grayed out; I don't know MSII software enough to remember why this happens, but it is grayed out.
Super_7
Post by Super_7 »
Hi!
Thanks for the answers.
It's 9 degrees in my garage actually! ;-)
I will check what's wrong around the IAT-sensor.
Furthermore I will reload the cody and generate a new .msq by taking over all relevant data manually.
I will report on this during next weekend!
Peter Florance wrote: all that stuff is grayed out; I don't know MSII software enough to remember why this happens, but it is grayed out.
He's using 2 point mode instead of tables.
Peter Florance
Man, it's been a while
2 point mode works for Cranking & ASE?
It applies to the priming pulse, cranking pulse, and ASE.
