Cranking RPM >700...what to do?
TwoStrokeRider
Post by TwoStrokeRider »
Hi guys!
I read in the "Tuning Your MegaSquirt"-Script that I should write to the forum if I have Cranking RPM >350.
So here I am. :)
My max. cranking speed is approx. 760rpm with a new battery.
As I read in the script I have to do some adjustments to the code.
What is to do?
What do the adjustments do?
TwoStrokeRider
Re: Cranking RPM >700...what to do?
I hope this is the reason why my engine won't start.
I tried many different values in the "Cranking Pulsewidth"-Settings...without success.
TwoStrokeRider
Ouu...I'm sorry.
I use the code version 2.89
The code allows setting the cranking RPM that high; I would try setting it at 800 and see if you can get it started that way. There was a guy on another forum with a cranking speed of 2,000 RPM (a very weird attempt at putting an electric start on a weed trimmer engine) who managed to make this work.
EWflyer
Post by EWflyer »
My project bike, Kawasaki EX-250, idles at 1,300 RPM and after a bit of experimentation I discovered it likes 950 RPM for the cranking RPM.
Below that RPM number the VE table plus the ASE and WUE just weren't cutting it for cold starts. 900 RPM seemed to be the "hump" that the engine needed to get over for a successful start. Now it lights off reliably in cold start situations.
Interesting, I set mine to 250, starter can run to 350 rpm, and my idle is close to 1050 ±50, but I flat line my advance for all MAP bins, flat line my VE table for all MAP below 1100 rpm in my tables, and I got much more stable idle...it's like running alphaN for idle only, the rest is speed density at the moment.
The reasoning is any idle variations do not change the injection time or ignition values, and it seems to work.
