No RPM signal in Megatune
So I've got all my Yamaha sensors calibrated and hooked up to my Microsquirt, and made a base tune. The first time I powered it all up and connected to Megatune, all sensors looked good except TPS, which didn't appear to take my ADC values, and the crank position sensor. I did some searching, and found I needed to update my code in the Microsquirt and the megatune ini. I did all this and the TPS works perfectly now, and I'm getting no warnings when I burn an .MSQ to the microsquirt. But the RPM gauge still showed nothing. It is stuck at zero, not even giving incorrect data. I checked my wiring, the CPS is a VR sensor (a little Nippon Denso unit?) VR+ to 32, VR- to 33. I put a scope on the VR connections at the 35pin amp connector and the waveform looks fine, exactly like the one on the VR sensor page of the manual. I'm not sure why Megatune is not displaying a tach signal. Is there something in the configuration that could cause this? It seems like it should be something simple, having absolutely no signal show up. Here are my crank trigger specs.
12-1 trigger wheel on Yamaha 50cc 4 stroke.
24 skip teeth
no dual spark
using uS coil driver
I've attached a copy of the msq. This is the one I'm copying over for the later code version(Im sure there's a better way to do this) so I haven't added warmup or accel enrichment yet, but the core's there.
- Attachments
- megasquirt201002021742.msq
- (25.04 KiB) Downloaded 55 times
Re: No RPM signal in Megatune
Anyway, as far as the VR Sensor goes, I would sure like to get it to work, and if the opto sensor works, I don't know why the VR wouldn't. It just goes through some pretty robust circuitry. I guess now that I know the processor reads things right, I'll experiment with some more values. Do you think It could be related to the speed I'm testing at? I've only tried cranking speeds with the VR so far.
- Master Squirter
Also, about the injector not firing with RPM signal, does it make sense to anyone that It wouldn't fire using only a 12-0 toothed wheel input, because of lack of a way to index? I thought that made sense to me, but then I thought about the stimulator - I'm not sure about this waveform, but I think its just a square wave, yet it pulses the injector LED's.
- Master Squirter
I was running down to 0.3mm on a cam lobe (VR2), and 0.7mm on the crank (VR1), so it might be worth trying the spacers. I observed the smaller the air gap the lower the rpms were detected in MegaTune/TunerStudio. It was the cam lobe sensor that was the most problematic in my case, as I couldn't get a sync signal until 950 rpm, but I still think you'd see benefits on your cranking rpm if you reduced the air gap.CSM wrote:I checked out the air gap on the vr sensor, it is about 1mm...snip
