R51
Re: R51
Re: R51
Is there any downfall or issues with doing this internal mod? -Or 100% good to go? Or would it be safer just to add the 1k across the pins between the ampseal and pcb.
Externally, Pin 4 biased to 5v actually makes a cleaner signal for me than going to 12v. With this in mind, will just swapping r51 as i mentioned be the fix?
(your statement confuses me a little, as if your saying- as in production form, when pin 4 is grounded, the voltage is pulled down to 1.8v. If the resistor R51 is changed to a 1k, then the voltage will be pulled down to 4.5v. ) If this is the case, i understand the circuit a little better and you already answered my question in the first post.
So to get this straight, i can bias the input circuit to either 5v or 12v with R50 & R51 mods. And there is no downfall or risk in doing so.
Re: R51
If you want to add an internal pull up, why not solder a through hole resistor to the pins on the AMPSEAL itself?
Re: R51
I was just looking at doing the mod on pcb as I have 3 version 1's that i am updating/ swapping smt diode and resistor for through hole. (D5 & R26) I figured another resistor swap on pcb was easy enough at the same time. And a little cleaner. The version 1's i have are just test units kinda and not critical. Any version 2's will be across the pins.
