Wiring Hall effect on OptoIn
Posted: Tue Jan 05, 2010 11:36 am
by g-snoop
Hello,
I'm trying to understand how to wiring my hall effect on my MicroSquirt but I'm afraid to do bad thing, So...
My hall effect is a VW part, and had 3 pin: +, -, signal.
I think I should do this:
Optoin + --> hall signal
Optoin - --> hall - and grounded
vref 5v --> hall +
Is it correct ? :oops:
Re: Wiring Hall effect on OptoIn
Posted: Tue Jan 05, 2010 11:51 am
Opto + & - are OK, but be careful, I think most Hall effects from VW are +12V IIRC, I doubt yours would be 5V. Have you got a part number to check against, and then Xref it in a "Google' search etc 8)
Posted: Tue Jan 05, 2010 12:21 pm
by g-snoop
Thanks for quick reply !
You're right, I checked it and my hall sensor is 12v !
So it should be:
12v --> hall +
Also, do you think I should do the 1kohm mod (between optoin+ and 12v) ? I read some topics about troubles with vw hall sensor, that requires this mod...
Posted: Tue Jan 05, 2010 5:14 pm
by 800vtwin
If you get high rpm drop outs/tach loss, you can put a 1k resistor from either 5v reference or 12v to hall signal. (opt+). I think it depends on the output and what rpm you will see.
Is the hall effect for crank? Is it 1 trigger pulse per revolution?
Posted: Wed Jan 06, 2010 4:52 am
by g-snoop
It is a four window hall effect for cam. So, it's two trigger pulse per crank revolution.
Posted: Wed Jan 06, 2010 11:04 am
by 800vtwin
Is this the signal for crank location?
Is there any other sensors or is the cam hall effect the only one?
Posted: Wed Jan 06, 2010 11:10 am
by g-snoop
No more sensor, the cam hall effect is the only one !
Posted: Wed Jan 06, 2010 11:13 am
by 800vtwin
ok, just checking.
Your last hook up is right. Just try it, if you get drop out, put the 1k pull up resistor from 12v to cam signal.
Posted: Wed Jan 06, 2010 11:20 am
by g-snoop
Ok, thank for help 800vtwin, I appreciate :D
