Hi,
I picked up a Borg Warner IAC valve (#22971, 2 wire, for a Crown Vic ) to play around with on my DIYPNP. So far I am unable to get the valve to do anything but buzz at various frequencies. There seems to be no movement of the valve under any condition when using the idle valve test feature and varying the "run" IAC steps from 0 to 100, only changes in the audible buzzing. Have tried frequencies from 30hz to 300hz in the 30-something hz steps allowed.
The IAC valve:
Connector:
The FB Diode in place to the 12v IAC:
I'm starting to wonder if this IAC valve I'm using is bad?
I am bench testing with the DIYPNP hooked up to a PC and the aux 12v for power. I am applying 12v from the board (12v jumper hole) to one side of the valve connector, and my IAC jumper to the other side. I have tried reversing polarity to the same effect. I can confirm that resistance between ground and the IAC jumper varies from ~inf to 0 as I vary the Idle PWM% with the idle valve test.
Thoughts?
