MAP spikes
MAP spikes
I'm running a 2.7l 4 cylinder NA engine (Porsche 944) on Microsquirt version 1fuel and spark. The car is running well but I am getting MAP spikes fairly often.
The MAP sensor is a 3bar GM unit and is fitted right back by the ECU. I have fitted a small inline fuel filter and also a 1.5 mm restriction in the pipework but I am still getting Accel enrichment spikes.
I have tapped into the vac line just behind the throttle plate which goes to the fuel pressure regulator, could that cause issues?
James
- Attachments
- 2009-07-14_16.58.27.msq
- (25.05 KiB) Downloaded 298 times
- 2009-07-14_16.50.59.msl
- (529.53 KiB) Downloaded 283 times
Re: MAP spikes
Re: MAP spikes
Start the car and I still get the spikes, it has improved now and only does it on idle so far today driving it seems ok. Will need a long drive to be sure.
Can't do too many miles at the moment as British summertime (torrential rain) has kicked in with a vengance.
Any other idea's?
James
gboezio
