Ms hardware changes
Martin Wagner
Ms hardware changes
We are using a 36-1 crank wheel with a ford VR sensor driving injectors and coils directly. When the unit fails, the tach drops and jumps a few times in the 3 to 4000 range, and the car either backfires or ignites unburnt fuel in the exhaust like the unit has lost sync or reset, then it quits completely. Any ideas what component(s) might cause this? VB921s? 5 volt regulator? Poly fuse?
- Site Admin
Re: Ms hardware changes
http://www.microsquirt.com/viewtopic.php?f=87&t=23063
- Brce
Martin Wagner
Both cars are V1 boards. I had already read the topic but it started with D5 and went on to several different diode, capacitor, and resistor changes and finally ended up with a code fix. We did install code version 2.890. I assume you are suggesting the D5 change and not the other changes mentioned in the topic.
Since I will have to order parts anyway, what part did you use to replace the SS12's on the V2 board. The SMD part looks large enough to solder without too much trouble.
Thanks,
Marty
- Site Admin
Martin Wagner
I installed a V2 microsquirt I have just purchased from DIYAutotune and the car ran fine for a 6 lap heat race. The V2 then failed with the same symptoms on the second lap of the feature race.
So, I now have 2 cars that both run with 1 V1 unit and fail with either a second V1 unit or a V2 unit.
Anyone got any ideas?????????
- Site Admin
Martin Wagner
Since the tach out signal was still working, power and vr in must have been working. I wouldn't think map, clt, or iat being out of spec would cause a shutdown. If map went to 0kpa it might be so lean it wouldn't ignite in the engine. I did hear a couple of pops in the exhaust while coasting to a stop in gear. But the problem happened in 2 different cars with 2 different sets of sensors. We are using both ign and inj outputs so I wouldn't expect both ign or both inj outputs to quit at the same time. I wasn't too surprised that the v1 unit still failed after the diode change but I was VERY surprised when the new v2 unit failed so quickly with the same symptoms.
I will figure out some way to mount the laptop but would still like to try something.
Marty
- Site Admin
Martin Wagner
Marty
- Site Admin
The injector loads are fine. One thing I would look into is to use remote coil drivers. Although I do not think this is the problem, especially since you have the same thing with VB921 and BIB373 drivers, doing this may help. Again, grasping at straws here without evidence of where it is failing. So get it in the bad mode and quickly check the spark and the fuel.
Be sure to check other systems like fuel, etc.
