Connection but no sensor readings
Posted: Sun Dec 07, 2008 12:08 pm
by micke_lc4
I just powerd up my new Microsquirt with IAT, MAP, CLT and TPS. MT connected without any problem but I can´t get any sensor readings. When i try to calibrate the TPS it shows -2 on both idle and wot and when i try to callibrate the IAT and CLT MT crashes.
The MAP readings is 100,6 but it dosent change if i blow or suck in it.
Is there somethin i missed or has anybody got a ide about whats wrong?
Edit: It also say that Batterys low, but if i mesure it is 12,6V
Micke
Re: Connection but no sensor readings
Posted: Tue Dec 09, 2008 4:56 am
by micke_lc4
Problem solved :yeah!:
Reloaded the firmware to the latest version (2.888) and then everything worked.
(dicoverd that i posted in wrong forum...sorry for that)
