spikes in my vr signal?
Posted: Thu Oct 02, 2008 11:26 am
I can get my motor to run, however in megatune my rpms read all over the map. The bars on the bottom, ase,wue, etc flicker from side to side.
This is my setup. I am running fuel only, I am sharing the vr sensor that runs my cdi box. I am running my vr wires to the cox vr input wires on microsquirt. My flywheel only has 1 wide tooth on it to trigger vr sensor.
What should my ignition settings be set at in megatune?
