Intake manifold tubing
When fitting the injector bungs, how far recessed from the intake runner should the tip of the injector be? Is it important to have the injector aimed at the intake valves? Is there an angle relative to the intake runner that the injector should be? Space constraints may limit just how much I can dictate the design but if'n I can I may as well make it as Ninja as possible.
SQLGUY
- Experienced Squirter
Re: Intake manifold tubing
For my bike I made the intake manifold out of copper pipe fittings which are a bit thicker than 1/16", but I think 1/16" would be plenty... Aluminum is usually more ridgid than copper. If it doesn't deform noticably when you squeeze it by hand, it should be OK.
For injector placement, I simply did the best I could within space constraints, the access I had to the intakes (rubber boots limited how close I could get), and to get the injectors aimed as close as I could towards the middle of the intake stream. My injectors are probably aimed further "down" than what would be optimal, and I don't know how perfect my X-Tau is, but the running results for the engine are pretty good.
obxer
http://www.jenvey.co.uk/
http://www.dtafast.co.uk/Throttle%20bod ... #positions
If you search for similar terms as found on these pages maybe you'll find info specifically for bike systems.
