new at this need help asap
adam
SQLGUY
- Experienced Squirter
Re: new at this need help asap
Once you've installed Megatune and run the configurator, you should be able to launch Megatune. The first thing you need to do in Megatune is go to Fuel Setup\General and set your ECU type. That will stop the fuel pump on/off cycling. From there you can begin configuring Microsquirt.
If you can't connect, review the communication troubleshooting section here: http://www.megamanual.com/connect.htm
Cheers,
Paul
thanks again
adam
pommie02
go to the diy autotune web site and download the latest megatune. search the forums for communication errors. there is a section in megatune that has a troubleshooter area.
i tried a usb connector...it didnt work, have you got a card slot in your laptop...you can buy a serial port card.
there are tests in windows which can test your port for you...
dont worry about the code, when you get connected it will put the code at the top of megatune
pommie02
there are two sizes, 34mm and 54mm.
i paid $15 on ebay for mine
pommie02
in megatune setup which code have you selected ?
i used 2.8 i think....
open up megatune, go offline, go to general...in there somewhere you should be able to enter 2 for microsquirt.
i have nearly given up a few times...but now by bike is running, and i am tuning it.
you will sit there one day and it will all fall in to place
Use 2.886 from here: http://www.microsquirt.info/uscode.htm There are instructions at that link.
You can also get the latest (2.886) code and INI using the V2.0 downloader, which will get the code from the internet, and load the code to MicroSquirt as well as installing/activating the matching INI. There's more info here: http://www.megamanual.com/ms2/downl2.htm
