Sharing Coolant sensor with Microsquirt
I have installed Microsquirt on my Honda Vtwin bike.
I am using the stock coolant sensor and want to leave the instrument cluster gauge connected. Apparently this means I have to remove the microsquirt bias resistor. All the information I can find is for the normal megasquirt. Where is the bias resistor on the microsquirt? (picture if possible!) Also is there another way to share the gauges without me butchering the Microsquirt with a soldering iron?
Cheers.
Re: Sharing Coolant sensor with Microsquirt
I will just have the coolant gauge disconnected.
Still it would be good if someone who knows could post here to let others know how to remove/change the Bias resistor in Microsquirt
