Help with fuel system tuning/troubleshooting
Posted: Fri Apr 25, 2008 7:49 pm
Hi folks,
Now that I've got my basic ignition set up well enough to get the engine running, I could use some (maybe a lot) of help with understanding the fuel side of things.
Here's where I am so far:
Yamaha SECA 750 (air cooled, transverse four).
I'm using port injection with injectors and a fuel rail taken from a junk yard 1999 Hyundai Accent. They are Bosch, or Bosch-style, injectors rated at 14.25 lb/hr. I have fabricated an intake manifold from copper pipe, and attached a throttle body from a 1997 Ford Escort. The fuel pump is new, it's an in-tank Bosch unit originally intended (according to the eBay seller) for Harley Road Kings, but marked Saab. The fuel pressure regulator is the one that came with the Hyundai rail and injectors.
EGO is currently disabled. IAC is set to PWM warm up with default settings. I have an oil temp sensor but it is not yet installed in the crankcase, so the ECU always thinks the engine is cold. IAT is hooked up.
I was initially not able to get the bike running. Some of that was ignition problems (now solved) and some was fuel problems. What I found is that if I set the injector flow rate to 5lb/hr or less I can get the bike running and it will idle OK (a bit uneven, but stable). Of course, this is about a third of what the flow rate should be for these injectors. I have verified that the bike will not run if I recalculate required fuel based on 6lb/hr or more.
With the 5lb/hr, the bike idles a bit high (around 1800 RPM) and this will actually drop if I try to give it more throttle. Too much throttle and it will start misfiring.
If I set the required fuel based on 3lb/hr, the idle comes down a bit, but the engine will respond to throttle, a little bit, still not able to rev much.
I pulled the injectors at one point and test fired them. They seem to spit more than emitting the fine spray I would have expected. I also pulled another set of the same injectors from the junk yard. I test fired one from that set as well, and it also spat the same way. The plugs are new, but after a while running they are fairly sooty. I have not yet measured the rail pressure (as I don't have a gauge and was hoping to avoid buying yet another tool for this project, but...)
Ambient pressure, per the MPX4250, is about 79kPa. When idling, the map pulls down to somewhere in the 65-68kPa range. I really don't understand how I'm supposed to use these numbers in the generate VE table tool. Does any of this help me come up with a better number to put in for map at idle in the tool?
Suggestions, thoughts, ideas from here?
Paul
Paul
