v2.884 release
v2.884 release
Attached is a new release that has two changes from 2.883j:
The spark retard input variable for the Rev Limiter was made a positive-only variable, since no one would advance spark to limit rpm. This expands its range to 0 to 25.5 deg, instead of +/-12.5 deg
The injector test mode was found to have been broken, and is fixed in this version.
The only reason for a new ini is to allow you to properly use the RevLimiter retard beyond its present range. Lance will post the corrected ini when he sees this post.
main_v2.884.zip
(76.65 KiB) Downloaded 71 times
Monitor_v2.884.abs.zip
(37.31 KiB) Downloaded 68 times
