Extra TL1000 Throttle Body for project
Posted: Tue Mar 04, 2008 9:46 am
I have an extra Throttle body that I will sell cheap. It is the second half from a TL1000R @ 49mm with a lever arm and post to control the position. There is only a closed stop on it. It has the TPI mounting features on it. I chose the other side for my SRX conversion for the other adjustments and am finishing up the adaption to mount the TPI to it. E-Mail me at kg6hbh at sbcglobal dot net if you are interested in it.
It comes with two injectors (Both mounted in the TB with a rail to feed both injectors). I will also cut off the two extra connectors so that you can wire them up. I will mark the common wire for you too.
I can also include the link that worked the throttle if you want it.
The inlet side has a three hole pattern that can be used to attach a filter adapter.
I am only looking for $20 plus shipping for it. That is about half of what I paid. It is light so shipping should be about $5 in the states.
Robert
Robert
