Microsquirt on single-rotor Wankel rotary engine
Posted: Tue Oct 16, 2007 12:10 pm
by CupraV6
Hi,
I want to use Microsquirt on a single-rotor Wankel rotary engine and after having read the details about Microquirt I assume that this is possible.
As this is a complete build-up from scratch I would like to get your advices on what sensors to use best, trigger wheels, ignition, injectors.
Nothing is decided yet, so I m open to your suggestions
Or is there even anybody out the who has ever done this?
Best regards
R.C.
Posted: Wed Oct 17, 2007 5:39 am
by Matt Cramer
This should be possible. Does your Wankel have one spark plug, or a leading / trailing split?
I'd probably use GM type sensors as those are the defaults, and probably a 36-1 or 60-2 trigger wheel. Depending on your spark needs, the Microsquirt can fire a coil directly, or you can use a CDI ignition box.
The injector size will depend on the horsepower output you're expecting.
Posted: Wed Oct 17, 2007 4:36 pm
by CupraV6
The Wankel has 1 spark plug.
Do we have to use a 36-1 oder 60-2 wheel? or could we also use a 12-1 wheel ?
RC
Posted: Thu Oct 18, 2007 5:38 am
by Matt Cramer
Ok, that makes things a bit easier. While 36-1 and 60-2 are the most popular, a 12-1 ought to work too.
