Dual Spark Ignition
Posted: Fri Aug 24, 2007 4:38 pm
by Flatline_Racing
I have just ordered a microsquirt and have been looking at the installation instructions and other documentation and could not quite wrap my head arround how to wire up the dual spark for my application.
I have a 78 Suzuki GS1000 (inline 4 wasted spark)that i have converted from Points to Dyna S electronic pickups. Each pickup drives one of the 2 coils.Is it possible to have the Dyna S hooked up to the microsquirt so that i will be able to adjust my timing and get rid of the mechanical advance?
Posted: Mon Aug 27, 2007 7:00 am
by Matt Cramer
You should be able to bring in 1 pickup through each of the inputs and have Microsquirt fire the coils directly.
Re: Dual Spark Ignition
Posted: Mon Aug 27, 2007 1:12 pm
by Bruce Bowling
From the drawing, it looks like the Dyna S electronic pickups also are a ignition amplifier, since the outputs go direct to the ignition coils. In other words the high-current drive is part of the Dyna S.
If this is the case then what you will want to do is pull the output high with, say a 1Kohm resistor, and hook this junction to the VR inputs of uS. The pullup resistor setup should provide the switching squarewave needed. However, the first VR channel in uS is set to 150mV crossing, so you may wan to use the opto input for the first channel. The second VR input trip point is higher at 1.8V, so this would be perfect for the second pickup.
Posted: Mon Aug 27, 2007 4:39 pm
by Flatline_Racing
Ok, this is my understanding of your advice, is this correct?
Here is my guess at megatune settings:
Ignition input capture: Falling Edge
Cranking Trigger: Calculated
Coil Charging Scheme: Standard
Spark Output: Going High (Inverted)
Posted: Mon Aug 27, 2007 5:10 pm
by Bruce Bowling
Yes, so far everything looks correct. I would give it a try...
Posted: Tue Aug 28, 2007 5:04 pm
by madman280
I have a similar set-up. A GS1100 2 valve engine in a lotus seven clone running a Dyna S too. I'm interested in how this works out.
How many watts would the resistors need to be?
Posted: Tue Aug 28, 2007 5:11 pm
by Flatline_Racing
I Think that it can be a normal 1/8 or 1/4 watt resister. All that it is doing is pulling the output high instead of leaving it floating. Assuming 12v and a resistance of 1kOhm then the current through it will be 12mA. If I am wrong could someone who knows please let me know before i 'F' something up.
FLR
Posted: Wed Aug 29, 2007 12:18 am
by newtyres1
Use a 1/2 watt resistor to be safe, it's not really any/much bigger, the 1/8 watt could get warm at high revs, depending on duty cycle.
Ian.
Posted: Thu Aug 30, 2007 9:04 pm
by Flatline_Racing
newtyres1 wrote:Use a 1/2 watt resistor to be safe, it's not really any/much bigger, the 1/8 watt could get warm at high revs, depending on duty cycle.
Ian.
Yeah, I guess that it is better to play it safe.
