Relay board???
Posted: Tue Jan 30, 2007 11:52 am
Will a relay board off a motorcycle work with MicroS?
looking for a small water tight system.
Read only forum for MicroSquirt(R) from Bowling and Grippo
https://microsquirt.com/
I am going to a cycle salvage Fri. , what do I need to look for to make sure it's wired correctly?sparkandfuel.com wrote:Assuming the fuse box is wired correctly for Microsquirt there should be no reason you can't use your oem fuse box.
Yes. As long as it has relays that switch using the low side of the relay coil.toon2 wrote:Will a relay board off a motorcycle work with MicroS?
What is the " low side" of the relay coil?MegaScott wrote:Yes. As long as it has relays that switch using the low side of the relay coil.toon2 wrote:Will a relay board off a motorcycle work with MicroS?
