Auto tune
Scott Bruce
Auto tune
Post by Scott Bruce »
I am using MS-II with a 3.0 board,and 2.36Megatune with a wide band sensor
Has any one seen at the bottom of the screen while in the auto tune mode, It say out of window?
Scott
Mike_Robert
Post by Mike_Robert »
Scott, if you search http:\\megasquirt.info, answers to most common questions are usually found. For example:
From http:\\megasquirt.info , search key "autotune":
Tools/Autotune
Autotune is an algorithm built into recent releases of MegaTune that automatically tunes your VE table based on EGO feedback. It is similar to MSTweak3000, but operates in real-time, without a datalog, and on any variant of code and processor that uses MegaTune.
The VE value inside MegaSquirt's RAM memory is modified and your engine feels the effect immediately, but it is not burned to flash and made 'permanent' until you click "Burn Table". If you do not burn the table, the changes will be lost the next time the power is cycled on MegaSquirt.
With a narrow band sensor, you can use auto-tune with any algorithm and any sensor to tune the low-power part of the table, it will get you to stoich (or AFR targets) quite nicely, which will give you a starting point from which to extrapolate the high-power part.
You don't need a dynomometer to get the high output regions of the VE table done, but you definitely should NOT use auto-tune with a narrow band sensor for that part of the table, you'll end up with broken or melted pistons. In order to use auto-tune for WOT tuning, you must be running a wide band lambda system (sensor and controller), with an appropriate EGO correction algorithm that allows you to set specific AFR targets (i.e., MSnS-Extra or MS-II). If one of these requirements is missing, then you must rely on seat-of-the-pants and experience.
To enable autotune, select 'Tuning/VE Table1/Tools/Autotune'. An autotune status text indicator will appear in the message window in the lower right corner of MegaTune. Note that auto-tune updates the VE table in RAM, and requires that you click "Burn" to save the changed VE table permanently.
Beware that if you go so rich that you start to see misfires, the lambda sensor will read the unburned mixture as dead lean (since unburned oxygen is present) and the closed loop algorithm will attempt to add fuel, which the auto-tune algorithm will detect and adjust the VE bin richer, thus making a bad situation worse. Use with caution, auto-tune will not perform magic!
Typically, acceleration enrichment and decceleration enrichment happen while the engine RPMs are changing quite rapidly, and they usually turn off EGO correction at the same time, pretty much negating those two conditions.
To start with, set the EGO step size (in MegaTune) to 1%, and set the authority down to ~10%, so that auto-tune doesn't do unstable jumps. The default auto-tune gain is 50%, so if you could jump a VE entry by as much as 5% in a single operation with the above numbers.
The EGO control algorithms all turn off correction (i.e., set the correction factor to 100%) whenever AE, decel, warmup or any number of other enrichment types come active. The 100% EGO value in turn has the effect of turning off the auto-tune.
The EGO correction step doesn't come into play at all, that's only internal to the EGO algorithm itself and dictates how rapidly it moves when correcting. The auto-tune step is determined by the current EGO correction (which is limited by the EGO controller authority), and the proportional gain, so only those two values really play a role in computing how big the auto-tune step will be. So, things proceed like this:
1. The EGO algorithm uses whatever means necessary to come up with a number, this is limited to 100% +/- EGO authority with the familiar algorithms.
2. The auto-tune algorithm uses the EGO correction value from 1, multiplies its difference from 100% by the gain to get the adjustment proportion. Gain is 0.5, EGO correction is 110%, then the VE adjustment will be 5%.
There are a number of parameters that affect the operation of auto-tune. These are written into the custom.ini file:
* allowAutoTune = on
* corrector = egoCorrection
* Vertex tolerance parameters
o xRadius = 200 ; rpm
o yRadius = 7 ; map
* Tuning block parameters
o xLimits = 1500, 4000 ; rpm
o yLimits = 60, 90 ; map
o zLimits = 10, 200 ; VE
* Controller parameters
o initialStartupInterval = 1.0 ; seconds
o updateInterval = 1.0 ; seconds
o proportionalGain = 0.5
o lumpiness = 5 ; percent
The radius (or vertex tolerance parameters) is how near to a vertex the operating conditions must be before the VE will be adjusted. For example, with the above settings, auto-tune will adjust a vertex if the operating point is within 200 RPM and 7 kPa of that vertex. If you increase the radius parameters, which would allow tuning farther from a vertex, then you may be changing the wrong vertex (typically four are involved at any given time, but auto-tune only changes the nearest one). The radius parameters try to minimize this error by only tuning when the nearest vertex has overwhelming influence.
For the limits (or tuning block parameters), "X" is RPM. Y is normally MAP, TP or load. Z is the VE itself. The limit parameters box the tuning points, no changes will be made outside the box. The radius parameters dictate how close the operating point must be to the tuning point for auto-tune to operate, if the operating point falls outside this smaller box, then no action is taken. If you change the limits, then you don't change the accuracy or speed, just the region that is valid for tuning.
Initial startup interval is the time in seconds between when the operating point approaches a tuning point and when the first adjustment is made.
The update interval is the time between each subsequent adjustment.
Proportional gain is how much of the ego correction is used to adjust the VE value. If you set it to 1.0, and the ego correction indicates a 15% error, then the VE will be adjusted by 15%, while gain of 0.5 will adjust VE by 7.5%. I'd suggest keeping this at 0.5 or lower.
Lumpiness is a parameter to limit how far a vertex's VE can be adjusted. The example below will keep the vertex that is being tuned within 5% of the extremes of the four surrounding vertices, under the assumption that the table should be somewhat smooth and will be 'rough tuned' to start. Note that the limits are transient, so if auto-tune changes vertex A by +5%, then moves to adjacent B, which also goes +5%, then the limit when we return to A will now be 5% above B.
[AutoTune]
table = veTable1Map
There are two diagnostic messages to tell you what is going on with the auto-tune algorithm when it is turned on, but isn't doing any tuning. They are:
* "Auto-tune: Tuning point outside window", which indicates that the operating point has gone outside the global x and y limits, so the no action will be taken. Likewise
* "Auto-tune: Tuning point not near vertex", which indicates that the operating point is inside the global window, but it is not near enough a vertex (as defined by the "radius" parameters), and so no action will be taken. These messages are intended to help you figure out why the algorithm is not changing a vertex on the table, and allow you to modify the xLimits, yLimits, xRadius and yRadius parameters accordingly.
Note that there are no menus to configure auto-tune in MegaTune (other than the EGO parameters). All the other data that MegaTune displays in dialogs for you to edit is stored somewhere inside your MegaSquirt; the tuning parameters for auto-tune are just MegaTune-specific data and really have nothing to do with MegaSquirt. This means that you need to edit the custom.ini file to make changes to the tuning algorithm's parameters. You may have to add to the custom.ini file:
; Add your customizations here, they will be read at the end of the
; standard megatune.ini processing and override any settings there.
[AutoTune]
table = veTable1Map ; Should be the map3d_id of a TableEditor entry.
allowAutoTune = on
; Vertex tolerance parameters
xRadius = 200 ; RPM
yRadius = 7 ; MAP
; Tuning block parameters
xLimits = 1500, 4000 ; RPM
yLimits = 60, 90 ; MAP
; Controller parameters
To make auto-tune work with earlier versions of MSnS-E (which require a INI file written before auto-tune was implemented) you'll need to use an old settings.ini and custom.ini, but cut the [AutoTune] section out of the new MT carMtCfg/custom.ini and paste it into your old one. Once you do this, you should scan your audit.log in the car1 directory to make sure that you are reading the old files an no new ones from the MT directories, as these might mess things up.
