Ping under low boost
Minami Kotaro
Sorry about the total newb question but I want to get this engine tuned right.
v2.2 board, MSNS-e 024s11
Check out my ongoing success story.
To play it save, I would pull out about 10degrees or so and roll it back up some. If you are getting pinging, then the advacne is way too much.
If you had really safe timing and compared dynos, you could watch the power increase as the advance is increase....then you will get to an adv number where you won't get anymore power. SO you increase another degree, and another, and no pwer in being gained...then you add another degree and it losespower and my ping. The point is, if it is pinging, then you could have a window of like 5 degrees where you are over the max advance you need.
