Number of injections?
MS-1 V3 running fuel and spark on MSnS-E 029s
Also.... setting the bins to the same value doesn´t mean that the afr:s are the same at slightly different kpa:s around idle, not for me anyways. I´ve carefully adjusted them so that when the engine runs a little "easier" and therefor goes down in kpa:s the ego correction doesn´t bear off on the wrong direction.
A bit tricky but when all is set it works lika a charm, it´s important that when the kpa:s go down in value that the bins are somewhat lower there so that the egocorrection doesn´t have to overcompensate to the leaning out direction, cause when it has to do that the engine will start to have a rough idle that tend to hunt a bit and the egocorrection swings wildly up and down.
I´ve HAD to finetweak this and some other areas by hand, none of the "auto mapping helpers" like autotune or the feature in megalogviewer has doned this right.
I believe I have a 2.0MS PW @ idle. This could be my issue with the hunting AFRs. What is this hi-res code you talk about? I run MSnS-E 029s. Woudl changing to 1 squirt fix my issue?snillet wrote:If you´re pending around 2ms pulswidth at idle you should try the hi-res code, my machine was doing a bit like yours but when i switched to hi-res 08 it disappeared.
BMW M50 Non Vanos 24v 2.5L Turbo MS-1 V3 running fuel and spark on MSnS-E 029s
Posted by email.
Last version is in the first post. But it´s not considered "finished" yet though.
It´s based mainly on the 029 code though so i should not worry to much. The only function taken out of the extra code to make room for the hi-res improvement is the PWM control for the injector current but since you´re running hi-z injectors that shouldn´t be a problem
It´s just as stable as the 029q2 was for me before i changed.
Ok I will check it out - is there any new settings that I need to use to take advantage of the high res injection? Like, is it a feature that goes un noticed except in car performance or do I have to set it up or anything? Also, does it make that much of a difference?snillet wrote:Check in to the msns-e 1 /development area on the forum and you´ll find the thread.
It´s based mainly on the 029 code though so i should not worry to much. The only function taken out of the extra code to make room for the hi-res improvement is the PWM control for the injector current but since you´re running hi-z injectors that shouldn´t be a problem![]()
Posted by email.
It´s just "there" when you switch to that codeversion, it´s just like switching to any newer extra code so it´s nothing tricky.Jon k wrote:Ok I will check it out - is there any new settings that I need to use to take advantage of the high res injection? Like, is it a feature that goes un noticed except in car performance or do I have to set it up or anything? Also, does it make that much of a difference?snillet wrote:Check in to the msns-e 1 /development area on the forum and you´ll find the thread.
I even loaded in my old 029q2 msq file, it did protest about errors in audit log but after i saved it and reloaded it again nothing went wrong. Although you should experience som need for remapping, since the calculation of the pw is more precise. Read the thread i was talking about earlier and you will understand that part...
The only difference you´ll notice when opening MT is that the numbers on the PW meter has more decimals....
Ok - and one more question, I "believe" my PW is = 2.0 or < 2.0 at idle. I have not log to look at right now but I do recall seeing that in MT. Would that cause instability of my idle afr? I forget what the acceptable minimum PW is.snillet wrote:It´s just "there" when you switch to that codeversion, it´s just like switching to any newer extra code so it´s nothing tricky.Jon k wrote:Ok I will check it out - is there any new settings that I need to use to take advantage of the high res injection? Like, is it a feature that goes un noticed except in car performance or do I have to set it up or anything? Also, does it make that much of a difference?snillet wrote:Check in to the msns-e 1 /development area on the forum and you´ll find the thread.
Additionally, would using the Hi Res code still function with the latest megalog viewer and its VE Analyze function?
Posted by email.
