Page 1 of 2
V8: Fuel Rails system diagram HELP
Posted: Sun Sep 10, 2006 3:34 pm
by 65looter
I think, I might know the answer to all my troubles (putting aside the rpm mini spikes....)
I believe I have connected my fuel rail the wrong way, hence the fuel issue while driving, me think.
Here's a diagram of my actual fuel lines:
Here's a diagram of what it should be:
according to http://www.mass-floefi.com/PICTURES/FOR ... oseNEW.jpg
you can see, this is not a Vincent van Gogh painting, but paint is good enough for me :)
Is there someone that could confirm my findings?
cheers.
Posted: Sun Sep 10, 2006 3:54 pm
by chicksdigwagons
Either way should be fine. There is really no functional difference except you'll probably have more balanced flow with the first picture.
by chicksdigwagons
Posted by email.
by chicksdigwagons
Posted by email.
Posted: Sun Sep 10, 2006 4:07 pm
by 65looter
are you sure?
I am having great difficulties tuning that megasquirt, so i am now looking outside the box :)
by 65looter
oops, i clicked twice.... :oops:
Posted: Sun Sep 10, 2006 4:13 pm
by Matt Cramer
If your fuel pressure regulator has two inlet ports, you might as well use them both. Is your fuel pressure OK?
Posted: Wed Sep 13, 2006 1:45 pm
by jeeptoylander
65looter,
This is what I did, you will find the XL diagram and component rating and a usefull link :
http://www.kinsler.com/
forget about the girl (pretty) on the cover page, download their catalog and read from page 71 and on.
If you want I have a pix of my own parallel injector feeder plumbing. The intermediate tank is a RCI all aluminium. To set some pump pressure you will need a pressure gage.
Bye
Posted: Wed Sep 13, 2006 1:58 pm
by 65looter
thanks m8, the page 71 is what i was looking for :)
cheers for that.
by 65looter
thanks m8, the page 71 is what i was looking for Image cheers for that.
SVO 342 stroker msq + logs MS-I, V3, MSnS-E 029 HiRes8f (fuel only mode)
Posted by email.
