Flyback board problem perhaps?
Posted: Wed Sep 06, 2006 10:59 am
(MS1, V2.2, MSnSE)
I'm running the MS on my 2.3T Ford with the low-imp injectors and built the unit with the flyback board with this in mind.
To get the car running I borrowed an .msq from someone and started there. One thing I didn't notice/pay attention to was their PWM settings, and later realized they had been using resistors instead of the FBB with their low-imp injectors. The PWM was set at 100% and 25.4 ms.
I realized a problem when one of the FI fuses blew when I was finally able to put the car under a bit of load (1-2 weeks of fiddling).
After digging into it and figuring out that I had the setting wrong, I worked on lowering the PWM to the "correct" values and went from there.
The thing is the idle has not been anywhere near as nice at 30% and 1ms as it was when things were set wrong. I messed with raising the PWM setting a bit (40-45% range) and the idle seems to clear up a bit. It's been about 3 weeks since I could really drive the car due to a broken clutch cable and weather issues, so I'm just getting back to this.
The car runs "ok" and starts fine (occasionally needs a restart, but that could be due to my cold-start settings), but it's not a clean as I think it could be. The idle was perfect before the fuse blew and I corrected the PWM settings.
Did I possibly damage something in the FB circuitry or even possibly the injectors (it was mentioned to me thaht it might happen)? The PWM setting is currently still 30% 1ms.
Chuck
Chuck
