tuning the VE table
Posted: Wed Sep 06, 2006 8:52 am
by turbo2go
Hi I've been working on tuning my motor (a 2332cc VW) with a narrow band o2 sensor got the VE table set (file vetable_NBO2.VEX). Then I got an inovate
lc-1 wide band o2 sensor and had to drop my ve table over 50% (file vetable_wb o2.vex). My question is is this normal or have I missed something.
I'm runningan MS-1 v2.2 through a relay board from DIY multi port injection with high impedance injectors @ 35lbs. I'm runnig megatune 2.25
Any help would be great.
Thanks Billy
Posted: Wed Sep 06, 2006 4:24 pm
turbo2go,
That depends on why you had to drop the VE. Were you aiming for a different AFR from the NB (which only tells you the stoichiometric mixture)?
If you were tuning to the same AFR, then it is likely that your LC-1 isn't set-up fully.
Posted: Thu Sep 07, 2006 6:49 am
by turbo2go
Thanks I'll look into the setup of my LC-1
Billy
