Page 1 of 2
spark autotune?
Posted: Wed Sep 06, 2006 5:13 am
by mkehler
I see a lot of posts on fuel autotune, but nothing about spark autotune. Is it because nobody uses it? Or? By tonite I'll hopefully have my fuel map pretty close..then its time to go after spark. Running extra code 029s.
thanks
Matt
Posted: Wed Sep 06, 2006 6:37 am
by FoundSoul
Autotune is for tuning a VE map and won't do anything for spark unless there is some voodoo magic I'm not aware of.
The only way to get a truly optimal spark map is on a steady-state dyno with a qualified tuner. There are several ways to get 'close', all of which involve some guessing or trial/error, but the dyno is the only real option if you want it just right. And not just any dyno... It must be a steady state load bearing dyno such as a Dyno Dynamics or DynaPack machine, or a Mustange, or several others.... An inertia dyno will not do the trick properly without the guesswork/trial and error so you're not much better than on the street.
Posted: Wed Sep 06, 2006 6:52 am
by FoundSoul
Here's a thread with a calculator that may help you get a base map (that will still need dyno tuning to get it just right!).
I haven't used it on a car yet, but looking at the map it generated for my MR2 it looks close enough that it appears to generate a decent starting point at least.
http://msefi.com/viewtopic.php?t=22161& ... highlight=
Posted: Wed Sep 06, 2006 8:01 am
by mkehler
Thanks Jerry. In the Tuning-SparkTable1 menu, you can turn autotune on directly...I had thought that meant there was a spark autotune (as it wouldn't make any sense to turn on autotune for fuel in the spark window, would it?).
So the autotune menu listing in the tuning-spark window either doesn't work, or actually activates autotune for the fuel map?
Matt
Posted: Wed Sep 06, 2006 8:07 am
by jsmcortina
Turning on the autotune feature while looking at a spark map will almost certainly make a mess of the spark map.
Also the VE specific "generate table" makes a complete mess of spark.
Only use these features on the fuel VE tables.
Posted: Wed Sep 06, 2006 8:12 am
by mkehler
jsmcortina wrote:Turning on the autotune feature while looking at a spark map will almost certainly make a mess of the spark map.
Thanks James. Out of curiosity, if using those functions within the spark menus makes a mess, how come the option is there? Is it something in place for future? Just wondering..
So the bottom line is....never use "auto/generate" anything for your spark maps. Do it all manually. Correct?
Matt
Posted: Sat Sep 09, 2006 4:57 am
by Matt Cramer
I think the reason they are there is that the spark map display software is basically a copy of the fuel map display software. So the AutoTune and automatic generator are simply copies of the fuel software.
Posted: Sat Sep 09, 2006 10:31 am
by Malachy
there is another generator here that someone from the 205gtidrivers forum has made, it seems pretty good
but remember its only to get a base map and then get it mapped/tweeked after
http://www.powerforum.dk/download.php?id=1933
Posted: Sat Sep 09, 2006 11:38 am
by 65looter
Malachy wrote:there is another generator here that someone from the 205gtidrivers forum has made, it seems pretty good
http://www.powerforum.dk/download.php?id=1932
"The selected Attachment does not exist anymore"
Posted: Sat Sep 09, 2006 11:40 am
by Malachy
sorry fixed now
