Getting best base VE map
itguy
Post by itguy »
Hi all
My car is running pretty well now, however because I use a wideband and have EGO active I wondered what the best approach is to fine tune the base VE map now as when I do a datalog then run it through MSLogViewer it doesn't change that much, however EGO is still making -15 to +15 adjustments when driving along, so the base VE map must still need fine tuning.
Am I best to disable EGO and then go for a drive while logging and *then* run through MSLogViewer analysis?
Will
PSIG
Re: Getting best base VE map
Post by PSIG »
itguy wrote:...Am I best to disable EGO and then go for a drive while logging and *then* run through MSLogViewer analysis?...
Will, that's what I am doing to remove as many variables as possible. Keep in-mind that both NB and WB sensors swing around while driving and will attempt correction that is not necessary. You may have noticed cruising on a flat portion of expressway with the rpm's and throttle steady and they still bounce around! This is why long, creative drives are good for averaging the data for better analysis. Maybe Phil has some other pointers about his very cool VE Analyzer.
David
snillet
Post by snillet »
megs of logs 8) , is my concept at least :D .
For the best averege.
Peugeot/Citroen XU5 BDZ(4cyl 1.6litre) engine with 60-2 VR wheel decoding singel coil and dizzy spark and Magneti Marelli(solex) TBI. Msns-E hi-res 0.08f and E85(Ethanol) in the gastank.
itguy
Post by itguy »
Is this the case even with EGO switched off?
I'm keen to get the best base VE map that I can so the EGO doesn't have too much work to do, as stepping down to -15 or up to +15% can take a few seconds and if the base VE map is off that much it can't be condusive to the smoothest running engine.
itguy
Post by itguy »
Quote: Keep in-mind that both NB and WB sensors swing around while driving and will attempt correction that is not necessary. Is this the case even with EGO switched off? I'm keen to get the best base VE map that I can so the EGO doesn't have too much work to do, as stepping down to -15 or up to +15% can take a few seconds and if the base VE map is off that much it can't be condusive to the smoothest running engine.
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135453#135453 -------------------- m2f --------------------
Posted by email.
ae1969
Post by ae1969 »
Definitely shut off ego control......
and run the ve analysis.
It took me 5 different logs to have it perfectly set me up.
Then you can turn the ego control and forget about it.
944 2.5 L Turbo EDIS 4 MS2
My Success Story
ae1969
Post by ae1969 »
Definitely shut off ego control...... and run the ve analysis. It took me 5 different logs to have it perfectly set me up. Then you can turn the ego control and forget about it. itguy wrote: Quote: Keep in-mind that both NB and WB sensors swing around while driving and will attempt correction that is not necessary. Is this the case even with EGO switched off? I'm keen to get the best base VE map that I can so the EGO doesn't have too much work to do, as stepping down to -15 or up to +15% can take a few seconds and if the base VE map is off that much it can't be condusive to the smoothest running engine.
944 2.5 L Turbo EDIS 4 MS2 My Success Story
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135480#135480 -------------------- m2f --------------------
Posted by email.
My Success Story
itguy
Post by itguy »
Great - thanks.
Out of interest how long (in time) were your log file sessions that you fed back into the VE Analyser and how did you structure your driving?
Was it certain revs held for a certain time at a certain throttle position/map etc? Or was it simply nice, varied driving?
Ooooo - did you disable AE too when doing your initial tuning?
itguy
Post by itguy »
Great - thanks. Out of interest how long (in time) were your log file sessions that you fed back into the VE Analyser and how did you structure your driving? Was it certain revs held for a certain time at a certain throttle position/map etc? Or was it simply nice, varied driving?
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135503#135503 -------------------- m2f --------------------
Posted by email.
LT401Vette
Post by LT401Vette »
You shouldn't need to disable AE. All AE records are filtered during log analysis. Actually, I wouldn't expect ego to negatively impact tuning either as it is factored into the calculation. I'll have to play around with that some more.
Phil Tobin
EFI Analytics
http://www.efiAnalytics.com/
